LTimW
#1 Posted : Tuesday, October 25, 2022 9:39:11 AM(UTC)
LTimW
I have built one system utilizing the Blackmagic Design DeckLink Duo 2 with fantastic results. I now want to build a larger system using the Blackmagic Design DeckLink Quad 2 for 8 SDI inputs.
The newest motherboards are not clearly specifying the 8x/8x option for the PCIe slots to accommodate the Graphics card and the Quad 2 card.
What currently available motherboard combination have you used successfully using the 8-input Quad 2 card without issue?
I would like to use a 3060 or 3070 graphics card.
montyfabio
#2 Posted : Wednesday, November 9, 2022 8:23:08 PM(UTC)
montyfabio
Italy
what's your cpu soket?
an example is MSI MPG Z690 CARBON
