3rd Party Software and Development
Just confirming...no way to change recording directory via API, correct?
Joined: 5/6/2016(UTC) Posts: 83 Was thanked: 5 time(s) in 5 post(s)
I have a use-case where I'd like to change the directory where recordings are made. From what I can gather, it's impossible to set either the recording directory or the recording filename formatting via API, correct?
Just wanted to be sure before I contemplate alternate ways of doing what I want.
Thanks!
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 57 Location: Canada
Was thanked: 17 time(s) in 16 post(s)
