Systems
Multiple logins. Presets not saving all settings
Joined: 12/3/2021(UTC) Posts: 2 Location: Oshkosh Thanks: 1 times
We are running VMIX 24.0.0.72. We have multiple students logging in to the machine. For security purposes on our campus they each use their own login. We have saved presets to the public desktop for them to use. The presets are not carrying all the settings through for each user. As a matter of fact, not even for the same user. For the same user the External output audio bus mapping does not save/recall once a new preset is opened. If I set it to bus a from master when I recall a preset that was originally master it will now be BUS A for that preset. Once a new student logs into the computer and calls up a preset Audio BUS A and B are not even enabled. Is there a settings file we can load in with each new profile on startup?
Joined: 2/18/2014(UTC) Posts: 1,817 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
You need to export and then import the Settings file too. And remember to import settings before opening the preset. (there are a bunch of feature requests in this Forum for a smoother process)
1 user thanked richardgatarski for this useful post.
Thanks. That works. Yes, it would be nice to make that all one file.
Systems
