Instant Replay
Virtual Zoom Improvements for Replay Input
Joined: 11/12/2012(UTC) Posts: 51 Location: Fort Walton Beach, FL USA Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
1) I'm using my Replay-A input to do virtual zoom and pans, which is very handy for review calls by official refs (basketball). However, the vMix Virtual Zoom PTZ controls only works if the replay video is playing (in motion). However, when paused, I can not zoom and pan. It would be helpful to be able to zoom into a specific area of the replay video while it's paused.
2) Is there a way to be able to use a joystick controller, such as my PTZOptics Superjoy PTZ controller, to control the zoom and panning within the zoomed Replay-A input (or any input set up to do Virtual Zoom)?
Joined: 12/27/2012(UTC) Posts: 5,091 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: rjmurdock 1) I'm using my Replay-A input to do virtual zoom and pans, which is very handy for review calls by official refs (basketball). However, the vMix Virtual Zoom PTZ controls only works if the replay video is playing (in motion). However, when paused, I can not zoom and pan. It would be helpful to be able to zoom into a specific area of the replay video while it's paused.
2) Is there a way to be able to use a joystick controller, such as my PTZOptics Superjoy PTZ controller, to control the zoom and panning within the zoomed Replay-A input (or any input set up to do Virtual Zoom)? What about using the shortcut functions to start with linked to a controller or even a mouse button combination ? Maybe this should be developed further ;-) which is basically translating coordinates to the mentioned shortcuts , intercepting a mouse for them could make it a fluid zoon/pan
Instant Replay
