bbestul
#1 Posted : Tuesday, June 22, 2021 1:53:58 PM(UTC)
bbestul
We are using Instant Replay functionality through vMix and using the vMix AVI codec for our videos. We want to use vMix Media Converter to convert them to ProRes Mov files like it says you are supposed to be able to do but when we select the audio file, and start the conversion, we get an error:
Audio Format Not Supported: 32bit Float
As far as we understand, that is the new standard and default for Instant Replay in vMix 24. Any way to solve this or are the video files unconvertable now?
#2 Posted : Wednesday, June 23, 2021 2:56:38 AM(UTC)
Was thanked: 4173 time(s) in 1498 post(s)
Apologies, this was an oversight and will be fixed in the next update, hopefully out in a couple of weeks.
The files can still be opened in vMix, Magix Vegas Pro or Adobe Premiere in the meantime, or you can export clips from replay in mp4 format from within vMix.
thanks 3 users thanked admin for this useful post.
eduardocfs on 6/23/2021(UTC), bbestul on 7/1/2021(UTC), AUSVIDE on 7/17/2021(UTC)
