bigboybradders
#1 Posted : Tuesday, May 12, 2020 6:09:03 AM(UTC)
bigboybradders
Hi Friends,
I am hoping someone can point me in the right direction.
This streaming thing is new to me and I have encountered as issue 3 times now that I cannot explain.
I will test the audio and all seems fine but then for some reason all of a sudden it distorts.
See here is a 20 second example
I was playing a video prior to this and then i opened the audio in the room and it was a mess.
My fix is to go to the input settings, press 'change' and select the same device again, press OK and all is good again.
Any thoughts where I should start to look?
If you notice a little cough before the piano starts it seems the distortion is only when there is noise.
Thanks in advance.
Brad
CorgieFan
#2 Posted : Wednesday, May 13, 2020 5:00:31 AM(UTC)
CorgieFan
I'm new to vMix as well but I've dealt with my share of audio issues in the past. If you're playing an audio/video on your computer outside of vMix your sound card driver might be causing a problem. When you say the problem is fixed when you "change" (reset) input settings again, it again makes me think your sound card driver causing a problem. I used to have an audio card that if I played an "outside" video or youtube web page outside the program I was working in it would cause my voice to speed up and get higher. I'd have to reboot my computer to fix it. If you have a different sound card you could test using it'd help isolate the issue maybe.
bigboybradders
#3 Posted : Wednesday, May 13, 2020 5:35:41 AM(UTC)
bigboybradders
Thanks CorgieFan.
I am actually using a DELL XPS 13 laptop thus it is entirely possible the internal sound card has the issue as I feel I am pushing the limits with an external monitor, stream deck, camera and mic, 2 streams etc. Originally I had separate mics which I stripped back to keep simple and hopefully avoid the issues but sadly they have continued.
I have a error shortcut key set up ready should it happen in the middle of a stream and will continue to monitor.
Thanks for the suggestion.
Brad
CorgieFan
#4 Posted : Wednesday, May 13, 2020 5:45:50 AM(UTC)
CorgieFan
I'd definitely try an external sound card then. I used to use a Focusrite Scarlett 2i2, I think vmix refers to using it in one of their videos as well. Huge step up from any internal sound card. Good luck.
