Hardware Compatibility
Aver Media Live Game Portable C875 Problem
I have also purchased this capture and gives me the same error during Vmix with Wirecast works perfectly for me with vMix tells me this grabber recognizes hopefully solve this problem, ! Hello everyone. I'm testing trial vMix (v12.0.0.120 x64) and am not able to add the input video source LGP I see 'LGP Motor Current "in the list of capture,. I have no problem with xSplit, Wirecast , VidStudio, OBS, Skype, ecc only see 'AverMedia C875 Capture ", but select an error has occurred." device does not recognize the command'? (AddNewInput) Anyone use this device need to configure something vMix., Use your Live Portable Gamer with any software compatible with DirectShow Now with the new LGP Engin Stream function, you can use the software that you like. Make your Live Portable Gamer is compatible with the popular streaming software as OBS (open Broadcaster Software) and endoderm Wirecast.Adobe Flash, Windows Media Encoder, XSplit, also can use software like VLC and use the codec that you like, there are a variety of possibilities, Here I leave link to see the compabilidad Soft product that allows smooth, I hope you solve this problem since I've always used vMix, Thanks Link...: http://gamerzone.avermed...ture/live_gamer_portable
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4172 time(s) in 1498 post(s)
Try running the 32bit version of vMix (the other icon instead of x64). The LGP driver is only able for 32bit.
Joined: 8/31/2013(UTC) Posts: 11 Location: Bielsko-Biała, POLAND Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Still problem with audio. Very bad quality. Any solutions? Solution: add camera [ LGPLite StreamEngine] with audio device: [ Built In Audio] (NOT [ LGPLite Stream Engine Audio] - selected by default)
Que puedo hacer si no me da la opción de (x32), cabe señalar que tengo la versión 22.0.0.48 (x64) Ayuda por favor
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 57 Location: Canada
Was thanked: 17 time(s) in 16 post(s)
Hi SDCHile,
The vMix 32bit version is included in every download and can be found in the vMix folder on your computer. Typically, somewhere like here: C:\Program Files (x86)\vMix
vMixGreg
