#1 Posted : Tuesday, April 16, 2019 1:27:11 AM(UTC)
Was thanked: 924 time(s) in 763 post(s)
first time i worked with the Instant Replay and I am confused ( workflow ) /missing a few understandings
When i have an event I can use the mouse on the event in /out to change the the timeposition which is not so easy to tweak an event especially after a few hrs into the production but it at least does tweaks the event time itself
For using the mouse wheel to move position i have to focus the mouse one the replay input ( or preview when there) but this does NOT adjust the in/out points , is this by design one has to in fact create a new event with specifying in and out when fine tuning said event?
The IR window especially unpinned doesn't seem to respond to mouse fine tuning hovering on the preview window off said window , seems to defy the purpose of having the IR controlled on second window/ second operator, sure i am just missing something.
Anyone care to clarify the general process of finetuning events for replay , is this then the same workflow when one uses a jog/shuttle to change positions ?
thanks
#2 Posted : Tuesday, April 16, 2019 10:16:13 AM(UTC)
Was thanked: 4176 time(s) in 1499 post(s)
You can use the following shortcut functions:
ReplayUpdateSelectedInPoint
ReplayUpdateSelectedOutPoint
These will update the selected event based on the position of the bar.
For more precise adjustments the following can be used to move frame by frame:
ReplayMoveSelectedInPoint
ReplayMoveSelectedOutPoint
https://www.vmix.com/hel...utFunctionReference.html
#3 Posted : Tuesday, April 16, 2019 4:20:52 PM(UTC)
Thank you
Shortcuts it is then (did find them between posts)
would have been nice to be able to use the mouse wheel while in the IR controller
I assume that a jogwheel controller will allow that being in front of a second monitor displaying the IR controller per simulating the shortcuts
Similar Topics
vMix Call And Audio Workflow (vMix Call)
by DAK313 3/15/2022 7:31:39 AM(UTC)
Replay workflow - live playhead (Instant Replay)
by tonsofpcs 3/10/2022 12:05:32 PM(UTC)
Vmix call audio workflow (vMix Call)
by Pingutheman 2/16/2022 4:23:52 AM(UTC)
Redundant System Workflow (General Discussion)
by TVisual 1/19/2022 10:26:34 AM(UTC)
Workflow - Using Master Preset with Customer Presets (Feature Requests)
by EpicVisionZone 2/28/2021 9:57:42 AM(UTC)
Dante workflow (General Discussion)
by jtoney 2/2/2021 10:21:44 AM(UTC)
IR workflow (Instant Replay)
by shftctrl 6/28/2020 6:18:56 AM(UTC)
50i workflow to stream at 25fps (General Discussion)
by openaspace 6/20/2020 1:41:05 AM(UTC)
Multiview Workflow (General Discussion)
by vmixuser47 6/20/2020 12:33:02 AM(UTC)
Preshow graphic and music workflow (General Discussion)
by DynamoBen 5/2/2020 5:46:01 AM(UTC)
vmix call audio routing workflow (vMix Call)
by lighting video 3/31/2020 3:36:25 AM(UTC)
VMIX Call 1080p and Workflow for Podcast (vMix Call)
by DDB 10/26/2019 5:40:06 AM(UTC)
Browser Performance Improvement breaking workflow (General Discussion)
by sim 10/15/2019 1:20:42 AM(UTC)
UTC Sports Workflow Question (3rd Party Software and Development)
by Jboze 8/7/2018 1:20:12 PM(UTC)
Connect Spark vMix Audio Sync workflow (NDI)
by SHMD 10/16/2017 8:54:12 PM(UTC)
Workflow 2nd Computer (Instant Replay)
by kjones9999 7/24/2017 9:56:28 PM(UTC)
Switch from SDI to IP - workflow example with vmix? (General Discussion)
by tgdzapa1 9/16/2015 3:35:08 AM(UTC)
Workflow to replay camera angles from in points sequentially, not at the same time (Instant Replay)
by jkmakela 2/7/2015 9:54:29 AM(UTC)
One small but big problem in 2 persons workflow in livemixing and slowmotion? (General Discussion)
by jkmakela 4/3/2014 4:31:17 AM(UTC)
vMix workflow diagram (General Discussion)
by mmorlan62 3/2/2013 5:14:05 PM(UTC)
50i workflow (General Discussion)
by dundurs 6/26/2012 3:17:38 PM(UTC)
