3rd Party Software and Development
vMix Script Builder App --Updated 11 July 2022--
Joined: 8/5/2017(UTC) Posts: 562 Location: Manitoba Thanks: 108 times Was thanked: 310 time(s) in 177 post(s)
Hi burie, It’s good that you can see the Input Names in the pulldown. That means you are connected OK to vMix. It sounds like you might be missing something in the command for controlling the title. If you add a simple « Cut » command, does it control vMix ok ? You can send me your file at info@studio793.ca if you like. I can have a look at it. Just use the export feature. Regards, Richard
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Originally Posted by: burie Originally Posted by: raugert Originally Posted by: burie Why does these tool not work with my vMix25 4k Version?
Please be more specific.. Does the application load ok ? Are you running the application from the vMix computer or on an another computer on the same network ? Can you see the input names from vMix in the Script Builder's "Input" dropdown ? If not, it's a network issue. Perhaps wrong IP and Port number ? Does the application load ok ? - Seems ok It is the vMix machine. The plan is usage with Tablet, but step by step... Yes, I can See the Inputs and the field names I am able to create multiple lines of commands, but if I click on "Test Script" nothing happens in my vmix titles vMix -> settings -> Web controller -> untick "Enable echanced security on Web and TCP API" -Tommi
Joined: 11/24/2022(UTC) Posts: 1 Location: stockholm Thanks: 1 times
A super big thanks for the software and your updates <3
