21.0.0.35 Colour Correction Bug
Joined: 10/1/2016(UTC) Posts: 117 Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
Hello, May have found a bug, or it is limited to my laptop. When I take any input and go to the colour correction screen with it turned on or off and quickly move the mouse over and around the the correction sliders I get the Red GPU Overloaded error in the lower section of the screen and the render time spikes. I took a couple screen shots as it seems strange that the GPU process does not really move in windows task manager if anything it goes down while wiggling the mouse/pointer over any of the colour correction controls. Screenshot (2) not moving mouse/pointer Screenshot (5) moving it around and changing settings Same happen in both 21.0.0.34 and also just tested same behavior in 21.0.0.35 I noticed this behavior on my mobile laptop setup with no cameras connected or with cameras connected and even in a new project with only colour bars. MSI Laptop i7 7700 2.8 GTX1050 16MB Ram 250 GB SSD 1024 GB HHD Attached a couple screen shots... SHMD attached the following image(s): Screenshot (2).png (468kb) downloaded 21 time(s). Screenshot (5).png (423kb) downloaded 16 time(s).You cannot view/download attachments. Try to login or register.
Shoot I posted this in a new topic - should have wen't in the vMix 21 preview release thread!
-s
Joined: 5/20/2015(UTC) Posts: 493 Location: Copenhagen, Denmark Thanks: 383 times Was thanked: 100 time(s) in 79 post(s)
I noticed the same weird behavior, when hovering the color correction faders. The mouse acts strange, as if it "lags".
