Instant Replay
Minor bug: Unable to change column widths
Joined: 5/20/2015(UTC) Posts: 493 Location: Copenhagen, Denmark Thanks: 382 times Was thanked: 100 time(s) in 79 post(s)
Hi vMixers,
In earlier versions it were possible to adjust the width of the columns in the replay module, but presently it is not possible. I wish to see it possible to adjust the column widths of the four input camera angles - the first few columns is fine by being fixed, but for the angles are important to have adjustable.
Best regards Jens Stigaard
Joined: 3/20/2014(UTC) Posts: 2,721 Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Thanks: 62 times Was thanked: 119 time(s) in 108 post(s)
This is still (or again?) happening to me in 24.0.0.63, and on a 2nd machine with 24.0.0.56. (FWIW, on a backup laptop running 23.0.0.65 it IS possible to resize the column width, though sometimes there suddenly appears another column while resizing, as if you have another camera.)
Is this a coincidence, that it's happening on two machines? Can anyone confirm this bug?
Currently, it is only possible to see approx. 19 characters of the event text, and in this case we need waaaaaaaay more to quickly find events... :)
The option to change the properties of the columns are greyed out. For all columns. enter image description here. Share. parts login portal
since last update in hosted I am unable to change columns width or resize windows?? Transaction are blurred. Using Chrome. dinar guru
Instant Replay
