Joined: 12/26/2020(UTC) Posts: 5 Location: Hamburg Was thanked: 5 time(s) in 1 post(s)
Is there a way to completly disable channel B? Often it´s just not needed. It would be nice to have a much bigger (and/ar adjustable) view of 8 cameras for replay. (yes, I can build an Multiviewer for this... but why so complicated) Often I wish there is also a way to "pin" an event list so it stays open the whole time as an Highlight list or similar playlist on the right side of the screen.
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 14 time(s) in 10 post(s)
When you say disable you mean don't use it, or don't see it?
If you mean don't use it, just stay on channel A.
As far as viewing, VMIX does not allow as of now much restructuring of the Replay UI aside from some basic things.
Just my option here but I personally don't think the VMIX team things of its Replay or GT graphics as potential stand alone feature but instead used in along side vmix as as the main switcher I agree though, it would be nice to be able to adjust, resize, hide things as needed. Maybe VMIX 26 will open up some more options there.
I am curious, do you use VMIX as only a replay machine on its own or as part of a single machine solution?
