Bob Brazner
#1 Posted : Tuesday, December 21, 2021 2:45:24 PM(UTC)
Bob Brazner
Does anyone have a script that demonstrates how I can duck one input based on volume level of another input? I know I can do this with Waves C1 compressor, but I'm hoping there's a script way to do it.
I was hoping to be able to figure this out for myself by reviewing the object reference for the vMix API, but I can't even find that. Can anyone point that out to me?
Peter1000
#2 Posted : Tuesday, December 21, 2021 5:22:08 PM(UTC)
Peter1000
Switzerland
Was thanked: 73 time(s) in 54 post(s)
thanks 3 users thanked Peter1000 for this useful post.
doggy on 12/21/2021(UTC), jelutalica on 12/22/2021(UTC), raugert on 12/25/2021(UTC)
Bob Brazner
#3 Posted : Wednesday, December 22, 2021 5:34:17 AM(UTC)
Bob Brazner
I watched this video, but unfortunately it doesn't include any information about the script itself. So, the hunt continues.
#4 Posted : Wednesday, December 22, 2021 6:45:21 AM(UTC)
Was thanked: 921 time(s) in 760 post(s)
The full script is in the pinned comment. The comments within the script can be translated with google translate
Stealth77
#5 Posted : Friday, December 24, 2021 5:02:45 AM(UTC)
Stealth77
Russian Federation
Was thanked: 8 time(s) in 4 post(s)
'--- Many thanks to Kirill Kudryavtsev @ kin0shkin from https://sbtg.ru/ for the script!
'--- Begin Script
dim translateInput as string = "Rus Translate" 'Input name with Translator
dim origInput as string = "Orig Program L" 'Input name with Original audio track
dim volumeStandart as string = "100" 'Volume Orig. input when the Translator is silent
dim fadeTimeStandart as string = "1200" 'Duration increase the volume Orig. when the Translator is silent
dim volumeSpeaking as string = "60" 'Volume of the Original input when the Translator speaks
dim fadeTimeSpeaking as string = "200" 'Duration fading Orig. when the Translator speaks
dim voicethreshold as string = "0.05" 'Response threshold to the interpreter's signal, from 0 to 1 (logical scale)
'Corresponds to the values ​​(not the length) on the volume slider: 0.5 = 50% ~ = -6dB, 0.1 = 10% ~ = -20dB ...
'Response may not work with a single pulse signal, but works well with a signal such as voice or music
dim checkingIter as integer = 10 'Number of iterations to check for translator silence before firing
dim checkingIterTime as integer = 200 'Interval (milliseconds) between check iterations (recommended from 100, default 200)
'So it lasts. verifying that the translation is silent and you can turn on Orig. = checkingIter * checkingIterTime (milliseconds)
'---- End of settings ----
dim voicemeter as string = ""
dim speaking as boolean = false
dim silence as boolean = false
dim silencechecking as integer = 0
dim muted as boolean = false
do while true
dim xml as string = API.XML()
x.loadxml(xml)
voicemeter = (x.SelectSingleNode("//input[@title='"& translateInput &"']/@meterF1").Value)
if (x.SelectSingleNode("//input[@title='"& translateInput &"']/@meterF2").Value) > voicemeter
voicemeter = (x.SelectSingleNode("//input[@title='"& translateInput &"']/@meterF2").Value)
end if
muted = (x.SelectSingleNode("//input[@title='"& translateInput &"']/@muted").Value)
'API.Function("SetText",Input:="TextInput",SelectedName:="Timer.Text" ,Value:=voicemeter)
'console.writeline(voicemeter)
if voicemeter > voicethreshold And voicemeter.IndexOfAny("[E]".ToCharArray) = -1 And Not muted
if silencechecking >= checkingIter '<> 0 '!=
'console.writeline("Speaking")
silencechecking = 0
'API.Function("SetTextColour",Input:="TextInput",SelectedName:="Timer.Text",Value:="yellow")
'API.Function("SetText",Input:="TextInput",SelectedName:="Timer.Text" ,Value:="Перевод говорит! " + voicemeter)
Input.Find(origInput).Function("SetVolumeFade", volumeSpeaking + "," + fadeTimeSpeaking)
end if
'console.writeline(silencechecking)
else
if silencechecking < checkingIter
silencechecking += 1
end if
if silencechecking = checkingIter
'console.writeline("Silence")
'API.Function("SetTextColour",Input:="TextInput",SelectedName:="Timer.Text",Value:="white")
'API.Function("SetText",Input:="TextInput",SelectedName:="Timer.Text" ,Value:="Перевод молчит! " + voicemeter)
Input.Find(origInput).Function("SetVolumeFade", volumeStandart + "," + fadeTimeStandart)
silencechecking = checkingIter + 1
end if
end if
sleep(checkingIterTime)
Loop
'--- End Script
thanks 3 users thanked Stealth77 for this useful post.
jelutalica on 12/25/2021(UTC), Bob Brazner on 12/28/2021(UTC), jpetrie on 12/29/2021(UTC)
Bob Brazner
#6 Posted : Tuesday, December 28, 2021 8:42:07 AM(UTC)
Bob Brazner
Is there a way to unconditionally run this script upon loading a given preset? Or, must I start it manually with a shortcut or Stream Deck button?
#7 Posted : Tuesday, December 28, 2021 9:38:47 AM(UTC)
Assuming you started the preset manually, start it manually with a shortcut or Stream Deck (or other controller) button or open Settings -> scripting -> select script -> start
Can be potentially "dangerous" to autorun a script at preset loading , must be sure the script is completely bug free
Can always make a auto launch external option (bat file or alike) but must be sure all is fully loaded before commanding the script to run
Maybe a feature request ?
Bob Brazner
#8 Posted : Wednesday, December 29, 2021 8:41:20 AM(UTC)
Bob Brazner
I figured as much; an overt act (e.g., shortcut, button, etc.) is necessary to start scripts.
The script is great; it works perfectly and I like the settings for controlling how it behaves. The only thing I'm going to change is the variable names for the two inputs as my use case does not involve a Russian translator. This is turning out to be not as simple as it sounds. Any suggestions?
vMix-Viktor
#9 Posted : Wednesday, February 23, 2022 12:57:11 AM(UTC)
vMix-Viktor
Germany
Hey guys, thx for this amazing script :D
I unfortunately might have found an issue though:
When running the script with the "translator"-input unmuted nothing will happen until I muted and unmuted it again.
This happens every time that I start the script.
But of course, I'd like the ducking to happen as soon as the script has been started.
Any suggestions?
vMix-Viktor
#10 Posted : Wednesday, February 23, 2022 1:53:29 AM(UTC)
vMix-Viktor
Germany
Nevermind I found the mistake .D Here's the updated code:
'--- Begin Script
dim translateInput as string = "Source" 'Input name with Translator
dim origInput as string = "Duck" 'Input name with Original audio track
dim voicethreshold as string = "0.02" 'Response threshold to the interpreter's signal, from 0 to 1 (logical scale)
dim checkingIter as integer = 2 'Number of iterations to check for translator silence before firing
do while true
x.loadxml(xml)
end if
Console.WriteLine(voicemeter)
silencechecking = 0
else 'this has initially been missing so silencechecking could never reach the value of "2" unless the translator input has been silenced or turned down
end if
else
end if
end if
end if
Loop
'--- End Script
thanks 1 user thanked vMix-Viktor for this useful post.
Stealth77 on 3/13/2022(UTC)
Chris Daum
#11 Posted : Tuesday, April 19, 2022 5:28:50 AM(UTC)
Chris Daum
Germany
a while ago I posted an example.
Long time not used so no comlaining!!:-)
for example you have a moderator and then a video with sound running.
If now the moderator talks in his mic the video audio decreases
and is increased again when mod stops talking
Code:
do
Dim xml as string = API.XML()
Dim x as new system.xml.xmldocument
Dim HSLvl as string = ""
x.load("http://127.0.0.1:8088/api")
HSLvl = x.SelectSingleNode("//input[4]/@meterF1").InnerText
 ' adjust video level corresponding to mod mic level
if HSLvl >= "0.02"
api.function("SetVolumeFade", input:= 'video', value:= "50,500")
sleep(500) 'to have the audio level not jumping around...
else
api.function("SetVolumeFade", input:= 'video', value:= "100,500")
end if
'console.writeline(HSLvl) 'just for debugging and level monitoring
loop
mhngg
#12 Posted : Friday, September 8, 2023 9:23:38 PM(UTC)
mhngg
Pakistan
I was able to achieve this with one script that is available on youtube. Here is how it looks in action: https://www.linkedin.com...tm_medium=member_desktop
kirik
#13 Posted : Saturday, October 28, 2023 7:38:20 AM(UTC)
kirik
Russian Federation
Greetings! I am the same Kirill Kudryavtsev who wrote the script! Please tell me where the mistake was and what did you write instead? I have already prepared the second version of the script, it is very interesting to know about the incorrect code and its location!
