Systems
More licences of Vmix on same server
I have a general question about Vmix: If I have a server with better configuration and GPU, is it possible on the same machine to install 2 or more Vmix licences/software for 2 or more different channels for strimming?
Joined: 11/11/2016(UTC) Posts: 378 Location: Europe Thanks: 23 times Was thanked: 38 time(s) in 32 post(s)
at the moment, you can stream to 3 different channels with one license
Originally Posted by: xaver at the moment, you can stream to 3 different channels with one license Thank you for your answer, but I can not play 3 different playlists on Vmix with one licence. That is the reason why I asked.
Joined: 12/27/2012(UTC) Posts: 5,095 Location: Belgium Thanks: 284 times Was thanked: 922 time(s) in 761 post(s)
Originally Posted by: Vangel Thank you for your answer, but I can not play 3 different playlists on Vmix with one licence.
I can not drive 2 different groups of people in opposite direction in the same car at the same moment, what a bummer You could create some playout script that reads references from different (external) lists, check their play status that load them into a specific input that are tied to the input your are streaming with yada yada or play with list inputs ( edit: scratch that)
I know that "I can not drive 2 different groups of people in opposite direction in the same car at the same moment".
That is why my question was to take 2 Vmix licences on same server, so it is more like 2 cars for 2 different groups of people in opposite directions from the same parking lot at the same time. If not possible on same Windows10 OS, maybe someone have expirience with VM or something similar?
Originally Posted by: Vangel I know that "I can not drive 2 different groups of people in opposite direction in the same car at the same moment".
That is why my question was to take 2 Vmix licences on same server, so it is more like 2 cars for 2 different groups of people in opposite directions from the same parking lot at the same time. If not possible on same Windows10 OS, maybe someone have expirience with VM or something similar? Have you tried to enable "multiple instances" and just start vMix multiple times on the same machine?
Systems
