Instant Replay
Instant Replay Mark question
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
Is there a setting to change that when I hit the "-20" button while IN a current replay it doesn't automatically jump to that position and interrupt my current replay happening? Using Vmix24. I can't seem to get it to work. Maybe a setting I am missing?
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 14 time(s) in 10 post(s)
That does seem like a bug if it's doing more than just creating a new file.
You are saying it creates the new file and then autoplays it in place of the currently running replay?
Joined: 11/11/2016(UTC) Posts: 378 Location: Europe Thanks: 23 times Was thanked: 38 time(s) in 32 post(s)
Originally Posted by: jvphobic Is there a setting to change that when I hit the "-20" button while IN a current replay it doesn't automatically jump to that position and interrupt my current replay happening? Using Vmix24. I can't seem to get it to work. Maybe a setting I am missing?
If you are live in Recording the -20 makes a new event with a new ID But it will not jump to that position. If you playing a IR then you also can press "-20" to create a new event the position of the IR always stays where it is (and for me this must be because otherwise you can't play and mark at the same time)
For me when I am playing an IR in Vmix24 and I hit the -20 button it immediately jumps to that replay. I currently have it set to A/B but it doesn't seem to matter. But, if I hit mark in & then mark out, that does NOT happen. Only when I hit the pre-set buttons or use the function: Function=ReplayMarkInOut&Value=15.
So, I don't know if that is a bug or the way it is supposed to happen. If anyone else is using Vmix24 and can verify that is how it works for them as well, I would appreciate it.
Joined: 12/27/2012(UTC) Posts: 5,088 Location: Belgium Thanks: 284 times Was thanked: 920 time(s) in 759 post(s)
Originally Posted by: jvphobic If anyone else is using Vmix24 and can verify that is how it works for them as well, I would appreciate it. nope, doesn't happen
Instant Replay
