Instant Replay
Replay Camera CCTV 60fps
Joined: 9/30/2020(UTC) Posts: 6 Location: Ho Chi Minh Thanks: 2 times
Hello! I often use cctv IPC Dahua camera for livestream. Recently I used Replay feature but the system is not getting 60fps but only 29.97fps. I connect via RTSP protocol, the image is still receiving Vmix normally, just not getting 60fps in Replay feature. I tried the other way that via VLC rtsp it got 60fps but the latency is higher than rtsp. With Xsplit software, I see it still can receive full 60fps. Hope you help!
RTSP 29.97fps [img=https://drive.google.com/file/d/1qvd4yLwvwREYzviVCuk9OhiVggKU4jWw/view?usp=sharing]RTSP[/img]
VLC RTSP 60fps [img=https://drive.google.com/file/d/19a3kmYd6omdx45mrUVwYU9mbV8hRKPJM/view?usp=sharing]VLC RTSP[/img]
RTSP 29.97fps VLC RTSP 60fps
What Dahua camera model are you using, IPC???????
Most of them only have a maximum frame rate of 30fps.
1 user thanked SportsNetUSA.net for this useful post.
Originally Posted by: SportsNetUSA.net What Dahua camera model are you using, IPC???????
I use camera IPC-HFW5231E-ZE Datasheet: > 1/2.8” 2Megapixel progressive scan STARVIS™ CMOS > H.265&H.264 triple-stream encoding > 50/60fps@1080(1920×1080) > Smart Detection supported > WDR(120dB), Day/Night(ICR), 3DNR, AWB, AGC, BLC > Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
I need help!!! RTSP over VLC with same Camera IPC Dahua: it can receive enough 50fps RTSP over TCP with same Camera IPC Dahua: just receive 29.97fps
I need help!!!! RTSP over VLC with same camera IPC Dahua 50fps: Can receive enough 50fps RTSP over TCP with same camera IPC Dahua 50fps: Just receive 29.97fps
Instant Replay
