GT
How to Modify GT Animated Templates
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Can anyone advise on how I can edit one of the GT animated lower third templates in the GT Designer? For example, how do I find where those templates are located (file folder) and then how do I open those in the GT Title designer so I can change the colors of the elements and/or modify the template shapes, sizes, etc.
Thanks.
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4174 time(s) in 1498 post(s)
If you open the template in vMix, it will then appear in the recent list in the GT Designer File menu. Note that you should save it to a separate location once the changes have been made and that any animations in the modified template will not play into editions lower than vMix 4K.
Originally Posted by: admin If you open the template in vMix, it will then appear in the recent list in the GT Designer File menu. Note that you should save it to a separate location once the changes have been made and that any animations in the modified template will not play into editions lower than vMix 4K. Great; thank you!
GT
