charlie wrote:Runing on Windows 10 with vMix HD 20.0.055 x64 but vMixControler is OFFLINE. Try different ports is still OFFLINE. On Test have the message "vMix seems fine, or at lease... " but when is hit Connect to vMix" not go to Online - stay only on OFFLINE. How to fix that? EDIT: This version fix the problem: http://www.weir3d.de/fil...uler/alpha_07_14_102.zip... did you have some programmer to make more functions on vMix Scheduler like start stop recording, start-stop streaming, etc. How to fix it? Can you please give me source code?
Hello, may you help me, when i open the vcontroller can't opened and show up, and when it open, i push to schedule with vmanager the vcontroller like a not responding program and blank.. can you help me.. i use windows 7 64bit version.. thanks before..
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Hello, I use the vMix scheduler every day and works fine. The only problem I have is that "List" not work. Only when i put the list input on place one(input 1). Is there a solution for this problem?
Joined: 12/28/2019(UTC) Posts: 2 Location: South Florida
Is vMix scheduler still available? Does vMix scheduler provide an as run log? How can I get a copy?
Joined: 12/27/2012(UTC) Posts: 5,092 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Joined: 6/3/2021(UTC) Posts: 12 Location: Douala Thanks: 2 times Was thanked: 7 time(s) in 4 post(s)
1 user thanked 237dominique for this useful post.
