Systems
Advice on Sound Card?
Hi all,
We are here for your wisdom. We are looking for a 8 xlr mic solution that would directly and separately would go in Vmix. Which sound card would you recommand bitween those ones: - Behringer UMC1820 - Focusrite Scarlett 18i20 2nd Gen - Tascam US-16x08 - Presonus AudioBox 1818VSL - Steinberg UR824
An other references?
Thanks!
Joined: 3/7/2012(UTC) Posts: 2,607 Location: Canada Thanks: 33 times Was thanked: 501 time(s) in 470 post(s)
@ Al1cante Any of those devices will probably work fine with vMix, but it should be noted that the guys at vMix are most familiar with the Behringer line of products as those are the ones they have used and tested with the most as per the last question on the most recent Fun Time Live Show: ?t=32m11s Ice
Joined: 5/13/2014(UTC) Posts: 516 Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
With reference to the Tascam US-16x08:-
I've got one of these. Works fine as an ASIO device in vMix plus it has a built-in DSP-based monitor mixer which can be used to provide an independent analogue output mix of the individual analogue inputs combined with a feed (over USB) from the computer (eg. a vMix A or B Bus output).
Systems
