Feature Requests
Slide advancing, cue system
Joined: 3/12/2013(UTC) Posts: 7   Location: London Thanks: 1 times
Hi, is there a way to be able to change slides within vmix via acue system or slide advancer? I would really like to use the program on live events with presenters being able to control the slides Thank you
Thanks: 1 times Was thanked: 9 time(s) in 6 post(s)
paulmeheux wrote:Hi, is there a way to be able to change slides within vmix via acue system or slide advancer? I would really like to use the program on live events with presenters being able to control the slides Thank you You can change slides via a web browser. If the presenter has a smart device (laptop, iPad, smartphone, Surface, etc), they can bring up the Web Interface in their browser. To enable Slide Advance, you would add a Shortcut with Function "NextPicture" and Input "MySlides" (specify either your PowerPoint or your folder containing images). Additional shortcuts can be added for "PreviousPicture", "FadeToBlack", or "Restart". Jon
 1 user thanked jwolthuis for this useful post.
Thanks Jon,
but I really need them to be able to control it remotely while they walk around with a small slide advancer. is this possible?
If your slide advancer can emulate a keypress, you can use setup a shortcut in vMix directly, or use something like autohotkey to trigger it via the web interface from another workstation.
Thanks Grimble,
The cue system i use is a USB connection and is supposed to emulate the keys as you say. I will have another play and see if it works. Are there any settings which may prevent it from working?
Joined: 1/13/2010(UTC) Posts: 5,181  Location: Gold Coast, Australia Was thanked: 4419 time(s) in 1550 post(s)
Most slide advancers send PageUp and PageDown as the keys. These can be configured in vMix using the "PageUp" and "Next" shortcut key options.
Martin vMix
paulmeheux wrote:I will have another play and see if it works. Are there any settings which may prevent it from working? I _think_ if the vMix window doesn't have focus, it won't get the keypress. In this case, you can set up AutoHotkey to send it through, I think, regardless of what window has focus - use the ControlSend function - http://www.autohotkey.co...commands/ControlSend.htm
Feature Requests
