amsudeen
#1 Posted : Saturday, March 9, 2013 10:28:18 PM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
IN INDIA MOSTLY USING AVCHD CAMCORDER ( Panasonic AG-AC160 ) 1080-I.
THIS TYPE OF CAMCORDER INPUT SOURCE AND RECORDING FILES ' JERKY ' . HAVE ANY SOLUTION FOR THIS PROBLEM.
macjaeger
#2 Posted : Sunday, March 10, 2013 6:28:40 AM(UTC)
macjaeger
Could you explain what sort of "jerky" you see? Is the video stopping and jumping? Or are there ragged edges at moving objects? Ragged edges would be caused by interlaced video, try setting "Deinterlacing" to "Blend" in capture-settings. Stopping, jumping video might be too slow computer, or any number of hardware insufficiencies. What capture card are you using? What are your system specifications (cpu, gpu, etc.)?
amsudeen
#3 Posted : Thursday, March 21, 2013 12:11:34 AM(UTC)
amsudeen
INTEL DH-77-KC
I7 PROCESSOR
16 GB-RAM
GT-640 2GB GRAPHIC CARD
RAID 0
BLACKMACIG DECKLINK QUAD
CAMERA INPUT 1080I
OUT PUT 1920 X 1080 ( PAL 50I & 25P )
ragged edges at moving objects.
#4 Posted : Thursday, March 21, 2013 12:25:34 AM(UTC)
Was thanked: 4239 time(s) in 1514 post(s)
Please set the Deinterlacing option when adding the capture input to "Blend" to remove the jagged edges.
