Assignable keyboard shortcuts and muting the audio
Hello all,
Congratulations on the RC1 release...what a great tool this is! I reviewed the pricing and it seems fair.
I was noticing while using vMix on my notebook that sometimes I can get the left and right arrows on my keyboard to control the fader function but it loses focus as I mix. Would it be possible to assign the keyboard to specific functions? Handy if all the notebook has is the touchpad.
Also the audio jumps around a bit as different inputs are selected...I see that I can just take the check mark out of the Select box but a 'select none' or 'mute all' would be handy right on the main vMix for live mixing. I can mute the main soundcard volume but if I want to have a track playing from an external player I would rather mute vMix. The other thing I looked for was a 'no sound device' choice under Settings on the 'Audio' tab. I have my HD Realteck audio bus card disabled as it interferes with my firewire audio recording...this creates an error window while using 'Add New Input' > 'Video'. I resolved this by adding a USB audio card.
Hope that makes sense, William
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4173 time(s) in 1498 post(s)
There are a couple of undocumented shortcut keys already.
Function Key --------- -------- Cut 0 Fade 1 Fade 2 Fade 3 Fade 4 Fade 5 Fade 6 Change Preview Input q,w,e,r,t,y,u,i,o,p (in order as the inputs appear in vMIx, for example R would change to the 3rd one across)
Also, a mute all button is easy enough to implement, I may just enable an option in settings to mute all inputs by default then you can select what to enable as you need to.
