#1 Posted : Tuesday, January 10, 2017 7:12:11 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Hi!
Looking for a NDI to HDMI/SDI converter for windows...
Doesn't seem to exist so far, except this project for Mac, non-released yet
http://www.sienna-tv.com/ndi/ndi-outlet.html
Also looking (potentially as an alternative) for a NDI to Virtual Device (exactly like vMix Video and vMix Audio on External output). Or a "plugin" for VLC or FFMPEG allowing them to play NDI sources like regular inputs ?
Do you have links for me?
Yes I know vMix can do this. Looking for alternatives for a workflow study.
TIA,
Guillaume
kane
#2 Posted : Tuesday, January 10, 2017 9:43:07 AM(UTC)
kane
NDI Connect or NewTek Connect Pro can output NDI into a supported HDMI/SDI device (BlackMagic, AJA, Bluefish are some examples)
NDI Transmit can convert NDI into a virtual webcam/virtual sound card to go into other software products.
You can find more information on both here: http://newtek.com/ndi/applications.html
Kane Peterson
NewTek
#3 Posted : Tuesday, January 10, 2017 10:24:20 AM(UTC)
Thank you Kane. Yep I forgot NDIConnect can do it, I use it to capture only so far. Just downloaded NDI Transmit to try it out.
mavik
#4 Posted : Sunday, April 1, 2018 6:51:13 PM(UTC)
mavik
Was thanked: 166 time(s) in 148 post(s)
Even though it's a relative old post.
NDI to HDMI can be done with some PC Sticks like from Intel and use NDI Monitor in full screen. Plug into a TV and off you go. You might want to use a USB Ethernet adapter if you want to get a wired connection.
So far I haven't read any anouncements that the BirdDog can output a NDI source from the network. The Spark is only to NDI as well.
