Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
I have read somewhere that it is possible to access the replay window via a web interface like the one for remote control of Vmix http://127.0.0.1:8088 Can any one tell me if this separate web window does indeed exist and if so where would I find it Thanks in advance
Joined: 5/20/2015(UTC) Posts: 493 Location: Copenhagen, Denmark Thanks: 382 times Was thanked: 100 time(s) in 79 post(s)
mark wrote:I have read somewhere that it is possible to access the replay window via a web interface like the one for remote control of Vmix http://127.0.0.1:8088 Can any one tell me if this separate web window does indeed exist and if so where would I find it Thanks in advance Two things. 1 - There's no direct web controller interface for the replay module, however, you can setup shortcuts to handle the wanted functionality, which can be accessed through the web controller. 2 - You can popout the Instant Replay module inside vMix, and move it to a second monitor, and thereby use the instant replay module more effective. (the little pin-icon) in the corner of the instant replay module.
Joined: 3/7/2012(UTC) Posts: 2,603 Location: Canada Thanks: 33 times Was thanked: 501 time(s) in 470 post(s)
@ mark
I think you are mistaken, AFAIK there is no access to the actual 'Instant Replay' screen on the web interface. If you have set-up "Shortcuts" to control 'Instant Replay', those can be accessed via the web controller along with all of vMix's set-up "Shortcuts". I don't currently have "Instant Replay" so I could be wrong but I suspect what you've read was more along the lines of using the feature on another PC and feeding it back to the Production PC.
EDIT: DOH! stigaard beat me to the punch...
Groups: Joined: 1/17/2016(UTC) Posts: 142 Location: Nj
I had the same question,and someone suggested using team player so a second mouse can just be used to run the second screen so the guy using the mouse for switching doesn't have to be interrupted.....and looks good also win 7 ultimate does have Remote Desktop with multiple monitor support so a laptop can run replays from main comp remotely
