Joined: 10/23/2015(UTC) Posts: 458 Thanks: 20 times Was thanked: 225 time(s) in 129 post(s)
You can change color of ellipse by changing "t1" text. File Attachment(s): test.xaml (2kb) downloaded 122 time(s).You cannot view/download attachments. Try to login or register.
Joined: 7/8/2016(UTC) Posts: 49 Location: Ukraine Thanks: 11 times Was thanked: 5 time(s) in 3 post(s)
elgarf wrote:You can change color of ellipse by changing "t1" text. Thanx a lot
Controller updated with tags into list items. Example: list item text@tag. First postLoosk like it still actual in vMix 18 :-)
Updated with state dependent buttons, tribute to post #126. State dependent buttonsButton can check it's activeness by checking vMix API state, for example, you have script with OverlayInputToggle command, so button will light green if overlay is active and red if not. If you have more than one command in your script, button check statements for all commands (all overlays active or something else). First post
2 users thanked elgarf for this useful post.
Joined: 9/1/2015(UTC) Posts: 126 Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
@elgarf Excellent, thank you very much .. thus I will know which button is activated Thank you Thank you Thank you
@JAIRODJ, I saw that it very handy to see which button is activated, when I worked at volleyball broadcasting)
1 user thanked elgarf for this useful post.
Groups: Guests
Joined: 10/17/2016(UTC) Posts: 6 Location: New Zealand
Hi elgarf,
first of all "great work" and communication level with other members regarding UTC.
I have downloaded the 3 folders from your first post and was able to get a scoreboard and news headline going using UTC.
What I can't do is 'File/Save' which means I have to start all over again.
Any ideas?
@fundowner, hmm... if you can share log file it will help. It's in your documents, folder "vMix UTC/logs".
Groups: Guests
@elgarf... I found the file... it's massively long after doing a few things in UTC
2016-10-28 19:36:26.9992 INFO Loading mapped functions. 2016-10-28 19:36:27.0192 INFO Loading templates. 2016-10-28 19:36:27.1192 INFO Loading window settings. 2016-10-28 19:36:27.1432 INFO Trying to send function in async mode. 2016-10-28 19:36:27.2742 INFO Async function sended, result is "<vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>". 2016-10-28 19:36:27.2742 INFO Creating vMix state form <vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>. 2016-10-28 19:36:27.3082 INFO vMix state created. 2016-10-28 19:36:27.3082 INFO New model setted. 2016-10-28 19:36:27.3082 INFO Configuring to 127.0.0.1:8088. 2016-10-28 19:36:27.3082 INFO Checking vMix server. 2016-10-28 19:36:27.3082 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled. at System.Net.ConnectStream.BeginRead(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at System.Net.WebClient.DownloadBitsState.SetResponse(WebResponse response) at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result) 2016-10-28 19:36:27.3082 INFO Checking vMix server. 2016-10-28 19:36:27.3082 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled. at System.Net.ConnectStream.BeginRead(Byte[] buffer, Int32 offset, Int32 size, AsyncCallback callback, Object state) at System.Net.WebClient.DownloadBitsState.SetResponse(WebResponse response) at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result) 2016-10-28 19:36:27.4433 INFO Checking vMix server. 2016-10-28 19:36:27.4433 INFO Status changed to Online. 2016-10-28 19:36:27.4433 INFO Checking vMix server. 2016-10-28 19:36:47.0064 INFO Checking vMix server. 2016-10-28 19:36:47.0064 INFO Checking vMix server. 2016-10-28 19:37:21.6774 INFO Trying to send function in sync mode. 2016-10-28 19:37:21.6774 INFO Creating vMix state form <vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1" /><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>. 2016-10-28 19:37:21.6774 INFO vMix state created. 2016-10-28 19:37:21.6774 INFO Configuring to 127.0.0.1:8088. 2016-10-28 19:37:21.6774 INFO New score widget added. 2016-10-28 19:37:21.6774 INFO Opening properties for widget . 2016-10-28 19:37:27.0367 INFO Checking vMix server. 2016-10-28 19:37:27.0367 INFO Checking vMix server. 2016-10-28 19:37:27.0367 INFO Checking vMix server. 2016-10-28 19:37:35.0021 INFO Properties updated. 2016-10-28 19:37:42.1815 INFO Configuring to 127.0.0.1:8088. 2016-10-28 19:37:46.9438 INFO Opening properties for widget Home copy. 2016-10-28 19:37:47.0708 INFO Checking vMix server. 2016-10-28 19:37:47.0708 INFO Checking vMix server. 2016-10-28 19:37:53.1672 INFO Properties updated. 2016-10-28 19:37:55.5133 INFO Opening properties for widget Away. 2016-10-28 19:38:00.3526 INFO Properties updated. 2016-10-28 19:38:05.0698 INFO Configuring to 127.0.0.1:8088. 2016-10-28 19:38:05.0698 INFO New button widget added. 2016-10-28 19:38:05.0698 INFO Opening properties for widget . 2016-10-28 19:38:07.0809 INFO Checking vMix server. 2016-10-28 19:38:07.0809 INFO Checking vMix server. 2016-10-28 19:38:31.1763 INFO Properties updated. 2016-10-28 19:38:41.6989 INFO Trying to send function Function=OverlayInput1&Input=3 in async mode. 2016-10-28 19:38:41.7529 INFO Async function sended, result is "Function completed successfully.". 2016-10-28 19:38:42.2010 INFO Trying to send function in async mode. 2016-10-28 19:38:42.2010 INFO Async function sended, result is "<vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1">3</overlay><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>". 2016-10-28 19:38:42.2010 INFO Updating vMix state. 2016-10-28 19:38:42.2010 INFO Creating vMix state form <vmix><version>17.0.0.107</version><inputs><input key="b0a36d02-d991-424e-8019-fa43d84cc2dd" number="1" type="Image" title="end.jpg" state="Paused" position="0" duration="0" loop="False">end.jpg</input><input key="c1b03ea9-2a83-4e61-adef-23fd6f2f6452" number="2" type="Xaml" title="NewsHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">NewsHD.xaml<text index="0" name="Headline">HEADLINE</text><text index="1" name="Description">DESCRIPTION</text></input><input key="4ef7a8c1-0c08-48ba-a476-5fd0a72394ff" number="3" type="Xaml" title="ScoreBoardHD.xaml" state="Paused" position="0" duration="0" loop="False" selectedIndex="0">ScoreBoardHD.xaml<text index="0" name="HomeTitle">Home</text><text index="1" name="AwayTitle">Away</text><text index="2" name="HomeScore">0</text><text index="3" name="AwayScore">0</text></input></inputs><overlays><overlay number="1">3</overlay><overlay number="2" /><overlay number="3" /><overlay number="4" /><overlay number="5" /><overlay number="6" /></overlays><preview>2</preview><active>1</active><fadeToBlack>False</fadeToBlack><transitions><transition number="1" effect="Fade" duration="500" /><transition number="2" effect="Merge" duration="1000" /><transition number="3" effect="Fade" duration="1000" /><transition number="4" effect="Fade" duration="1000" /></transitions><recording>False</recording><external>False</external><streaming>False</streaming><playList>False</playList><multiCorder>False</multiCorder><audio><master volume="100" muted="False" meterF1="0" meterF2="0" headphonesVolume="100" /></audio></vmix>. 2016-10-28 19:38:42.2010 INFO vMix state created. 2016-10-28 19:38:42.2010 INFO Configuring to 127.0.0.1:8088. 2016-10-28 19:38:42.2010 INFO Calculating difference. 2016-10-28 19:38:42.2010 INFO Updating inputs. 2016-10-28 19:38:42.2010 INFO Firing "updated" event. 2016-10-28 19:38:46.6582 INFO Trying to send function Function=SetText&Value=2&Input=3&SelectedIndex=2 in async mode. 2016-10-28 19:38:46.6812 INFO Async function sended, result is "Function completed successfully.". 2016-10-28 19:38:47.0972 INFO Checking vMix server. 2016-10-28 19:38:47.0972 INFO Checking vMix server. 2016-10-28 19:38:47.0972 INFO Checking vMix server. 2016-10-28 19:38:48.5713 INFO Trying to send function Function=SetText&Value=3&Input=3&SelectedIndex=3 in async mode. 2016-10-28 19:38:48.6513 INFO Async function sended, result is "Function completed successfully.". 2016-10-28 19:39:07.1114 INFO Checking vMix server.
@fundowner, can you try save controller, then compress log into zip? Do you see save file dialog?
Joined: 7/1/2016(UTC) Posts: 48 Location: Italy Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
i need to create a scoring list with this data provided in an xml file Like this:
<DATA> <RECORD> <COLOR>7</COLOR> <INDEX>1</INDEX> <VEHICLE>4</VEHICLE> <PILOTNUMBER>25</PILOTNUMBER> <TRANSPONDER>4</TRANSPONDER> <PILOT>Pilot Name 1</PILOT> <CLUB/> <COUNTRY>HRV</COUNTRY> <LAPINFO/> <TREND>0</TREND> <LAPS>2</LAPS> <LAPTIME>26.394</LAPTIME> <ABSOLUTTIME>00:52.738</ABSOLUTTIME> <BESTTIME>26.344</BESTTIME> <BESTTIMEN>52.738</BESTTIMEN> <MEDIUMTIME>26.369</MEDIUMTIME> <FORECAST>23 10:06.487</FORECAST> <PROGRESS>24</PROGRESS> <DELAYTIMEFIRST>0.000</DELAYTIMEFIRST> <DELAYTIMEPREVIOUS>0.000</DELAYTIMEPREVIOUS> <STANDARDDEVIATION>0.035</STANDARDDEVIATION> <CARID>0</CARID> <VOLTAGE>n/a</VOLTAGE> <TEMPERATUR>n/a</TEMPERATUR> <SPEED>35.05</SPEED> </RECORD> <RECORD> <COLOR>7</COLOR> <INDEX>2</INDEX> <VEHICLE>3</VEHICLE> <PILOTNUMBER>5</PILOTNUMBER> <TRANSPONDER>3</TRANSPONDER> <PILOT>Pilot Name 2</PILOT> <CLUB/> <COUNTRY>DEU</COUNTRY> <LAPINFO/> <TREND>0</TREND> <LAPS>2</LAPS> <LAPTIME>26.817</LAPTIME> <ABSOLUTTIME>00:53.757</ABSOLUTTIME> <BESTTIME>26.817</BESTTIME> <BESTTIMEN>53.757</BESTTIMEN> <MEDIUMTIME>26.878</MEDIUMTIME> <FORECAST>23 10:18.195</FORECAST> <PROGRESS>26</PROGRESS> <DELAYTIMEFIRST>+0.473</DELAYTIMEFIRST> <DELAYTIMEPREVIOUS>+0.473</DELAYTIMEPREVIOUS> <STANDARDDEVIATION>0.086</STANDARDDEVIATION> <CARID>0</CARID> <VOLTAGE>n/a</VOLTAGE> <TEMPERATUR>n/a</TEMPERATUR> <SPEED>34.50</SPEED> </RECORD>
My problem, i can create a line with all the values in one record like this ?
1 Pilot Name 1 HRV 2 26.394 ................. 2 Pilot Name 2 DEU 2 26.817 ................. . . . . . .
@digitalalps, you can made XPath like this: Code:./DATA/RECORD/INDEX|./DATA/RECORD/PILOT|./DATA/RECORD/COUNTRY|./DATA/RECORD/LAPS|./DATA/RECORD/LAPTIME
it will make one value by row, so you can map each value to title placeholder.
Thx,
is working fine. Now i have a other problem:
The number of records in the xml is not fixed i can have 5 records, the next race 10 and so on.
I made a Overlay with 10 lies of datafields like this:
Index1 Name1 Time1 Index2 Name2 Time2 . . . Index10 Name10 Time10
If i have 10 Records works fine, when i have only 7 records the line 8 brings the first record. The data restarts at beginn
@digitalalps, hmm... I thought it was a good idea to restart data =) I'll make chackbox, where you can switch off data restarting.
I've updated controller with "Restart Data" checkbox, try it. First postP.S. Did anybody need timeline into vMix? Where you can place inputs or control properties like loudness/opacity/etc?
Has anyone any idea how to solve the following problem?
I have a variable long list of race results, which is deposited with a background. I would like to have the background but only as long as the list is long, so what is possible with UTC?
For example with individual graphical segments per line which are switched off and on? Thx for the help
Can you share your title? You can make triggers inside your xaml.
@digitalalps, you can make something like that (see attachment). File Attachment(s): NewsHD.xaml (6kb) downloaded 84 time(s).You cannot view/download attachments. Try to login or register.
This solution will work perfectly.
I'm always surprised how powerful Vmix is.
Thanks to Martin and the community
