blis
#1 Posted : Tuesday, November 2, 2010 8:39:23 AM(UTC)
blis
Greetings Martin,
You put a smile on some faces at work today, simple and broadcast like.
The wish list:
1) Drag and Drop of multiple files for inputs
2) Preset/playlist editor with drag and drop
3) Autoplay option on transition (eg - Automatically play output after transition)
4) Countdown timer (for the lazy ppl)
5) Audio mix?? Not sure but it seems to fade out and then in.
6) Input resize or text playlist.
h
#2 Posted : Tuesday, November 2, 2010 10:56:48 AM(UTC)
Was thanked: 4171 time(s) in 1498 post(s)
Thanks for the suggestions.
The next release (v9) will largely be a performance optimisation release but most of your suggestions seem easy enough for the release after that which will be vMix 2011.
vMix 2011 is due early to mid 2011.
Some comments for each suggestion:
1. Easy enough.
2. Would a playback queue be suitable? This would involve selecting one or more of the currently opened inputs that would begin playing one by one.
3. This is already implemented as the "QuickPlay" option that fades and starts playback automatically.
4. Would this be the standard SMTPE countdown or something a bit more specific?
5. When audio mixing is enabled (it is by default). It crossfades the audio automatically.
6. Inputs can be resized from the "i" button under the Position tab.
