virtual set zoom in and out speeds
Joined: 3/30/2014(UTC) Posts: 224 Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
Is there any way to change the default virtual set zoom in and out speeds? at the moment the speed settings are F=1 M=2 S=4 and C=0. So is there a way to change these settings and save them? see attached pic Thanks. Len. Len56 attached the following image(s): VS pic.jpg (16kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/2/2013(UTC) Posts: 1,031 Location: Fairhope, Alabama USA Thanks: 542 times Was thanked: 195 time(s) in 161 post(s)
Set "C" to whatever zoom speed you want. For example, 00:10 means 10 seconds.
sinc747 wrote:Set "C" to whatever zoom speed you want. For example, 00:10 means 10 seconds. Thanks, understand what you are saying but when I set C to 00:10 then click on F, M, S or C again the settings go back to there original settings.
Joined: 3/7/2012(UTC) Posts: 2,603 Location: Canada Thanks: 33 times Was thanked: 501 time(s) in 470 post(s)
Sounds like a good feature request to me, cuz I haven't found a "settings" option that will save such an adjustment.
Joined: 2/18/2014(UTC) Posts: 1,815 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
I believe I filed this as a small bug sometimes a year ago. In my view the last selected speeed should be saved with the preset.
Perhaps Martin could add a tab on the left hand side of the virtual set input settings saying something like "Camera Zoom Speed " and then we could insert our own speed settings for that virtual set. See attached Picture I have made. Len56 attached the following image(s): Virtual set settings pic.jpg (267kb) downloaded 25 time(s).You cannot view/download attachments. Try to login or register.
