2 Pages12>
#1 Posted : Tuesday, April 2, 2013 7:05:09 AM(UTC)
Was thanked: 4166 time(s) in 1497 post(s)
There is now a Products section of the web site where you can purchase additional Titles, Scoreboards, Clocks and Virtual Sets.
So far the previously announced vMix Title Pack 1 is available for $50 and there is a new Virtual Set available for FREE.
http://www.vmixhd.com/products.aspx
thanks 3 users thanked admin for this useful post.
dsharon on 4/2/2013(UTC), Adriankey4 on 9/24/2013(UTC), zul.ms on 11/21/2013(UTC)
Troviss
#2 Posted : Thursday, November 14, 2013 12:21:21 PM(UTC)
Troviss
Thank you for the new virtual studio set. This is the best so far I think. Well done! But it should be nice if we can get some list, or tips about where we can buy or load home new sets, as is ready to use without extra job to make them compatible. Is it possible to find sets with reflections on the desk and the floor? I mean sets as they use in Tricaster?
thanks 1 user thanked Troviss for this useful post.
GBIM on 3/27/2014(UTC)
jayala1974
#3 Posted : Saturday, July 19, 2014 2:32:59 PM(UTC)
jayala1974
There is no explanation on how to use set you buy at www.virtualsetworks.com. What format to you get? I got a free sample from them no clue on how to load the muilt-view sets. I get a "no config" error.
#4 Posted : Saturday, July 19, 2014 3:04:56 PM(UTC)
Was thanked: 920 time(s) in 759 post(s)
from what I was able to figure out is you basicaly get a bunch of images ( layers if its in a .psd form) and have to specify these ,'translate' , in a xml file (compared to the one already available in the virtualsetfolder of vMix)
I have no idea how they would work in other software settings directly in the way they are delivered.
There is a nice webinair vid showing how to treat the layers (tricaster) includng reflections and uv maps. if one saves the layers here as individual images and speify them in a vMix required xml you are good to go .
webinair
h60lly1sl5qy
#5 Posted : Friday, November 21, 2014 8:25:45 PM(UTC)
Rank: Guest
Groups: Guests
There and you will have be the case a multi function sign cheap beats by dre ificantly better at your Dr Dre Beats Headphones decision within this income range,however the Beats on the basis of dre Diddybeats earbuds continues online an all in one in line with the effort,a little as though go http://www.bandbuddys.com/inc/exe/forum//index.php?&action=vthread&forum=12&topic=160041 ing to be the audio included in the balance to do w
Slaver
#6 Posted : Monday, February 23, 2015 9:04:17 AM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hi Martin,
is it now possible to add countdown-timers in scoreboards for the gametime to start/stop it?
I cannot find any answers or information.
Thank you for reply.
Best,
Marvin
thanks 1 user thanked Slaver for this useful post.
steffiechun962 on 11/25/2016(UTC)
#7 Posted : Monday, February 23, 2015 12:28:24 PM(UTC)
Was thanked: 501 time(s) in 470 post(s)
@ Slaver
Just about any text field of the XAML Titles in vMix can be used as a countdown timer.
It is just a matter of setting it up in the Title Editor.
Highlight the field you want.
Go to 'Settings' beside the 'Countdown' controls and establish your parameters (ticking the 'Reverse' box will count up)
You are best to set up "shortcuts" to manage start/stop (use the pause feature for best results).
Slaver
#8 Posted : Monday, February 23, 2015 12:39:32 PM(UTC)
Slaver
@IceStream
Thanks for your quick reply to my question.
In the meanwhile i found it out by myself how to do the built in countdown but it just left one question.
Everything can be controlled with the web-function from another computer instead of the countdown option.
Is that correct?
Slaver
#9 Posted : Tuesday, February 24, 2015 7:54:01 PM(UTC)
Slaver
Somebody else with an answer for me?
Want to control the whole scoreboard(title) for a basketball-game on a different computer with the web-function.
Everything(points, fouls, quarter) works great but i can´t start / stop the time with this controls.
Is it not possible or is there another reason?
Thank you
#10 Posted : Tuesday, February 24, 2015 10:40:17 PM(UTC)
@ Slaver
Short answer is edits can be made but no controls for timer (AFAIK).
You might be able to use an external timer like "XNote Stopwatch" and do a screen capture but I would suggest experimenting with it...
I don't find it to be the most intuitive or simplest method of 'keeping score' but it might work.
#11 Posted : Wednesday, February 25, 2015 10:46:58 AM(UTC)
@ Slaver
On further reflection, you can also control the start/stop function of the timer via the web interface "shortcut keys".
It requires a separate window of the web interface, but it should be possible to have both windows open in your browser.
ZachSchuster
#12 Posted : Thursday, February 26, 2015 4:58:13 PM(UTC)
ZachSchuster
Slaver,
Is there a reason you need to do it via the web-function from another computer? CGStatLink (http://cgstatlink.com/cgstatlink-lite-basketball/) will run on another computer and give you all the controls you need, including game clock, , and render the multi-page CG as a PNG for vMix. With a simple mapped network folder you can save the PNG to the vMix computer and import it as a dynamic PNG source.
But if there is a specific reason to use the web-function, then disregard. Just throwing out another option.
Zach
thanks 1 user thanked ZachSchuster for this useful post.
Slaver
#13 Posted : Monday, March 2, 2015 9:17:37 PM(UTC)
Slaver
@IceStream
Thank you, but the shortcuts are not working even when i am in the shortcut window on the other computer.
@ZachSchuster
Easy explanation:
I have one computer for streaming at the gym. I cannot connect the real scoreboard or scouting with the streaming-computer. The webfunction allows me to control my selfcreated whole scoreboard with a second pc. The first computer can just be used by the guy who change cameras and put overlays on the Video. So it would be great when another guy can control the Quarter, Time, Points and Teamfouls. Everything is working great instead of the time thing.
Thats all and for sure after buying vmix i dont want to pay again.
By the way: How can i put a dynamic PNG source to vmix?
Slaver
#14 Posted : Tuesday, March 3, 2015 12:58:43 AM(UTC)
@ Slaver
How are you setting up your shortcut keys?
This works very well for me so I am surprised it doesn't work for you, unless you have the wrong web site address (I find it can change from set up to set up, so you have to check it every time you use the web interface)
I typically use my iPhone as a wifi connection to the web interface of the shortcut keys to control start/stop of the clock
rezgar
#15 Posted : Sunday, November 29, 2015 7:16:47 PM(UTC)
rezgar
hello admin
i want to ask how can i use ticker from left to right? thank you
thanks 1 user thanked rezgar for this useful post.
Eric Pratt
#16 Posted : Saturday, February 27, 2016 3:52:15 PM(UTC)
Eric Pratt
Was thanked: 12 time(s) in 6 post(s)
I've been getting a lot of questions about how to use our virtual sets with vMix so I put together a little tutorial walking users through how to load, configure, and edit sets:
http://www.virtualsetworks.com/Docs/vMix/index.vmix.htm
Enjoy, and please ask if you have any questions.
Thanks,
Eric
thanks 2 users thanked Eric Pratt for this useful post.
madness on 2/27/2016(UTC), steffiechun962 on 11/25/2016(UTC)
Slaver
#17 Posted : Wednesday, May 4, 2016 11:33:20 AM(UTC)
Slaver
Hello Guys,
i am still working on a possibility to work with a second person on the scoreboard for basketball.
The person just has to control the points, teamfouls and quarter.
Is there still no chance to press a button to count up the points one bye one and not settings the score complete new?
In my Attachement you can see what i mean.
Thank you
Slaver
Slaver attached the following image(s):
anselm
#18 Posted : Wednesday, July 27, 2016 2:34:56 AM(UTC)
anselm
Was thanked: 4 time(s) in 1 post(s)
I am working on a title for vMix but its behaviour its strange. The people on stack overflow doesnt seem to know why it wont run well on vmix since the said the xaml code is correct can someone help figure out the problem? The code and questions can be found on http://stackoverflow.com...ng-from-initial-position
#19 Posted : Saturday, January 14, 2017 2:08:40 PM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Slaver wrote:
Hello Guys,
Check this :
http://forums.vmix.com/d....aspx?g=posts&t=6468
#20 Posted : Saturday, January 14, 2017 3:23:22 PM(UTC)
when Headline contains a value ;-)
doggy attached the following image(s):
Screenshot (40).png (20kb) downloaded 3 time(s).
2 Pages12>
