melody
#1 Posted : Saturday, August 28, 2010 1:19:52 PM(UTC)
Rank: Guest
Groups: Guests
hi,
is there any possibility to implement a virtual audio output device, like vmix virtual capture but only audio (to use it in Adobe flash media live encoder or another)?
in Adobe flash media live encoder i can use vmix virtual capture and my realtek input line... its running ok... but if i use a hdv camera i have an image delay in real-time.
in vmix recording option we can chose audio delay in miliseconds, so the idea is, using the same system, implement a setting that is possible select audio input in virtual audio output device and choose how much delay i need to syncronize audio and video in adobe flash media live encoder.
regards,
melody
ps: if you can implement this feature, try to add an audio volume control and some volume input bars. thanks in advance for your attention.
radu2001
#2 Posted : Saturday, August 28, 2010 5:31:25 PM(UTC)
radu2001
Happened to me too. Being able to select a custom audio delay for FME would be great!
#3 Posted : Sunday, August 29, 2010 9:17:40 PM(UTC)
Was thanked: 4239 time(s) in 1514 post(s)
I've done some brief testing and it looks like I can just set a negative delay on the vMix Virtual Capture instead.
The testing I have done in FME has correctly delayed the audio, I will conduct some further testing to see if it works with other applications too...
We'll see if I can fit this into the v8 release.
melody
#4 Posted : Monday, August 30, 2010 1:07:51 PM(UTC)
Rank: Guest
Groups: Guests
wow, thats great...
if it help you, try to test with wndows live messenger and skype.
regards,
melody
