BBA_MEDIA
#1 Posted : Thursday, April 11, 2024 7:21:25 PM(UTC)
BBA_MEDIA
As a vMix user I have just migrated from my Loupedeck Live to a Stream Deck +. One of the functions of the Loupedeck vMix template was the ability to scroll through the inputs (back and forth) using a rotary control which you then pressed to take the chosen input to preview. Is this possible to recreate for the Stream Deck + ?
mavik
#2 Posted : Thursday, April 11, 2024 7:53:11 PM(UTC)
mavik
Was thanked: 168 time(s) in 150 post(s)
To my knowledge it isn't possible natively. You would need script or something. I struggle with the rotary knob implementation as often things don't just work as you would expect them to.
I tried to PAN a PTZ with one knob. I couldn't get it done properly at all.
BBA_MEDIA on 4/11/2024(UTC)
knbPixels
#3 Posted : Thursday, April 11, 2024 11:25:20 PM(UTC)
knbPixels
Should be able to do this if you use Bitfocus Companion to control your Stream Deck
thanks 1 user thanked knbPixels for this useful post.
