Install can't replace vMixVideo.ax
Joined: 10/13/2012(UTC) Posts: 1,161 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
Hi Martin,
No big issue but the installer will not replace vMixVideo.ax when I do an in-place upgrade. I choose ignore and the install proceeds. vMix seems to function normally afterwards. Any ideas?
Andrew
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4171 time(s) in 1498 post(s)
Hi Andrew,
It is important that vMix Video be updated during installation to make sure it is the latest version. The error usually means something like skype is running in the background with a connection to the file.
Martin vMix
Thanks..please get some sleep! Man can't live off brown carbonated beverages alone!!! LOL
Finally tracked down the program. It seems that both Skpye and Avermedia RECentral are the culprits. Interestingly I could quit Sskpye and that released the file but RECentral was not operating but still had a connection. So the workaround was to rename the .ax file, then run the new install.
Joined: 3/30/2020(UTC) Posts: 17 Location: Leran Thanks: 14 times
Just to say that the problem with Skype needing to be shut down is still occurring today with v.27 Shut down Skype - problem solved!
