Feature Requests
T-bar plays video on vMix Replay
Hello. I have one feature request about t-bar function in vMix Replay section. EVS and Ross system can play video if you move t-bar. To many operators suggest this to us so now we are sending this info to you. If you can add option to Enbale/Disable play video replay from T-bar. You can see how it is done on Ross Replay: https://help.rossvideo.c.../Replay/Panel-T-BAR.html
Joined: 8/2/2013(UTC) Posts: 1,033 Location: Fairhope, Alabama USA Thanks: 543 times Was thanked: 196 time(s) in 162 post(s)
If you are using a separate device with a T-bar, then you can change the vMix Shortcuts that executed by the T-bar to anything you want. No change in vMix required.
- Tom
Feature Requests
