Joined: 8/20/2020(UTC) Posts: 1 Location: Hilversum, the Netherlands Thanks: 4 times
We are using vMix al lot for it's vCall function. To integrate this more with the production workflow, I would like to be able to get more info from vMix inputs which are vMix calls.
I would like to be able to: - Get the status of a vCall input (connecting/connected/disconnected) - Get the status of a microphone or webcam (enabled/disabled on the user's side) - Get the password or vCall URL for an vCall input - Reset the password for a vCall input
This way I could integrate or create a platform for the producers to prepare vCalls and monitor them.
Also, I can't seem to add a VideoCall with the AddInput shortcut.
I would love to hear wether this is possible!
Kind regards, Max van den Bosch United
+1 for making it possible to add videocall (vMix call) with AddInput.
Joined: 4/23/2017(UTC) Posts: 1,144 Location: Germany Thanks: 3 times Was thanked: 166 time(s) in 148 post(s)
+1 adding - set a default image in case the input is down or new - select not only outputs but also inputs as the video source - remote control of cam/mic
Joined: 1/23/2022(UTC) Posts: 71 Location: Milton Keynes Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
+1 for having video/mic status in the master XML.
