Michael7687
#1 Posted : Thursday, February 29, 2024 1:24:04 PM(UTC)
Michael7687
I don't think this is a Vmix problem but it is affecting my Vmix audio Outputs.I am sure there is probably a simple solution, but for the life of me I can't figure out what it is... I am getting two audio feeds into the same monitor at the same time.Any Suggestions from you Computer experts?
dmwkr
#2 Posted : Thursday, February 29, 2024 8:40:43 PM(UTC)
dmwkr
Was thanked: 119 time(s) in 108 post(s)
Does it also happen when playing audio from another software on the vMix PC? How is the monitor connected? What are your Audio Output settings in vMix?
ovonder
#3 Posted : Thursday, February 29, 2024 10:10:43 PM(UTC)
ovonder
Try turning of the headphone volume (to 0) in the audio mixer master settings.
I have had "echo" issues which were caused by custom audio output settings, causing both the headphone and master going to the same audio output.
The master output had a slide delay causing an echo effect.
