GT
changing the color of the button
Hello, I have layers ready in GT for your questions. I want to change the background color from blue to green at the end - correct answer. I want to make a shortcut to change this background I used to do this - but either I forgot or something changed. Will it help find a solution? buttons.png (328kb) downloaded 0 time(s).
Joined: 12/27/2012(UTC) Posts: 5,103 Location: Belgium Thanks: 285 times Was thanked: 924 time(s) in 763 post(s)
Originally Posted by: ASLIVE MEDIA I used to do this - but either I forgot or something changed.
LOL oh your serious LOL things havent changed but things were added ;-) one can still use images as background to change (SetImage or visible/invisible) or the newer SetColor (of shapes) or whatch one of the many vMix Tutorial videos to refresh your memory like this one:
Thank you, you refreshed the topic for me. Everything works except one thing :] I change the color, but to create non-standard graphics you have to use Photoshop. And after importing to GT, unfortunately it only sees it as a Bitmap. So here I had to create a "rectangle" in GT and apply it to the graphic. I guess it's not possible to change the properties of an imported file from PS to GT so that it is seen as a "rectangle"? The shortcuts work great. test.jpg (232kb) downloaded 4 time(s).
GT
