jet
#1 Posted : Tuesday, December 13, 2022 11:48:50 PM(UTC)
jet
Was thanked: 15 time(s) in 13 post(s)
Found this years old post.
"vMix itself supports up to 8-bit 4:2:2 from most capture cards and then upscales this to 32-bit floating point 4:4:4 for all video processing
which helps a lot with things like chroma key processing."
Is this still the case with vMix 26?
If, then please enable support for true 10 bit input and output.
Now enormous amount of color information is thrown out of the window and only 8 bit video is recorded to 10 bit capable recorders.
paco3346
#2 Posted : Wednesday, December 14, 2022 12:29:34 AM(UTC)
paco3346
Was thanked: 34 time(s) in 31 post(s)
+1
I'm itching to see 10 bit on my LED wall
thanks 1 user thanked paco3346 for this useful post.
jet on 12/10/2023(UTC)
jet
#3 Posted : Tuesday, January 10, 2023 8:48:18 AM(UTC)
jet
OBS has it as standard
mavik
#4 Posted : Tuesday, January 10, 2023 4:23:31 PM(UTC)
mavik
Was thanked: 166 time(s) in 148 post(s)
+1
jet
#5 Posted : Wednesday, August 30, 2023 11:11:58 PM(UTC)
jet
This feature is essential!
vMix uses only 8 bit video and only 8 bit video is recorded to files and 10 bit capable recorders!
Now -still- with vMix 26 enormous amount of valuable color information is not used at all which would be very important when the footage is (post) processed!
Please add 10 bit support for input and output to vMix 27!
jet
#6 Posted : Sunday, September 17, 2023 4:02:29 PM(UTC)
jet
True 10 bit support is a must in a professional video software!
jet
#7 Posted : Saturday, September 30, 2023 6:07:03 PM(UTC)
jet
Up
Rinsky
#8 Posted : Saturday, September 30, 2023 8:38:08 PM(UTC)
Rinsky
+1
thanks 1 user thanked Rinsky for this useful post.
robert5521
#9 Posted : Monday, October 2, 2023 9:06:01 PM(UTC)
robert5521
Spain
Was thanked: 7 time(s) in 4 post(s)
+1, hopefully this includes also 10bit 4:2:2 SRT outputs.
thanks 1 user thanked robert5521 for this useful post.
jet on 10/8/2023(UTC)
jet
#10 Posted : Sunday, October 8, 2023 5:04:43 PM(UTC)
jet
+1
jet
#11 Posted : Monday, October 16, 2023 3:22:54 PM(UTC)
jet
Preview of vMix 27 released: Still no signs it would have 10 bit support in it....?
jet
#12 Posted : Friday, October 27, 2023 11:11:04 PM(UTC)
jet
With 10-bit color depth pixels can show up to 1024 variations of brightness, in other words 1.07 BILLION possible colors!!
Now vMix 27 beta (and eralier releases) uses still only 8 bit and only 256 variations of brightness is available and preserved!
So, please start adding 10 bit support to vMix ASAP!
#13 Posted : Saturday, October 28, 2023 12:51:37 AM(UTC)
Was thanked: 4173 time(s) in 1498 post(s)
Please avoid replying to the same feature request to try and boost it, it is unfair to other features.
As to the question of 10bit, it might help your case if you could explain a real world scenario for live video.
(There are certainly benefits to 10bit video in the post production world for grading etc, but these rarely translate into significant quality benefits for live or streaming video)
For example provide some screenshots demonstrating where a video signal you are using is significantly lower in quality due to 8bit vs 10bit.
10bit generally requires double the processing power of 8bit and would require us to build a separate pipeline to support it.
That is no easy feat and would represent the single largest change to the vMix code ever!
It is also worth noting that hardly any streaming providers support greater than 8bit right now (with the exception of perhaps YouTube, but even then only in certain cases where the end user supports HDR)
jet
#14 Posted : Saturday, October 28, 2023 5:25:25 AM(UTC)
jet
Hi Martin.
It's not all about live streaming!
Many shows may also be done "flat" color and the final color grading and editing is done in post and the files must be 10 bit!
Also producers usually wants the final "master" file be in the best available format for fine tunining and archiving.
10 bit has been on the way to main stream more than 10 years now and that YouTube link I provided was already over 5 years old!
vMix should give the user the choice to be able to use 10 bit workflow!
Kind regards,
Jan
yimmyo
#15 Posted : Saturday, December 9, 2023 2:29:25 PM(UTC)
yimmyo
+1
thanks 1 user thanked yimmyo for this useful post.
NiBTour
#16 Posted : Wednesday, January 31, 2024 10:23:21 PM(UTC)
NiBTour
Was thanked: 18 time(s) in 17 post(s)
+1
This is very much needed when recording as well as when passing feeds off to other systems.
thanks 1 user thanked NiBTour for this useful post.
jet on 2/3/2024(UTC)
