TL68
#1 Posted : Tuesday, January 16, 2024 12:54:20 AM(UTC)
TL68
Sweden
Hi!
Trying to run a custom command on a streamdeck button in companion with "SetRateSlowMotion" but fail to make it work.
If I do a vMix shortcut it works fine. So I think I must be using the wrong setting in companion.
Also: if I run the command in the browser it does not work either.
So this works:
Replay speed 2
This does not work (string used is: SetRateSlowMotion&Input=Preview&Value=0.5):
Replay speed1
In browser I run this:
http://localhost:8088/api/?function=SetRateSlowMotion&Input=Preview&Value=0.5
but speed is not set to 50%
But I get response "Function completed successfully."
Thanks for any help with this!
#2 Posted : Tuesday, January 16, 2024 1:17:14 AM(UTC)
Was thanked: 922 time(s) in 761 post(s)
Originally Posted by: TL68 Go to Quoted Post
Hi!
Try using the specific input name/number instead of preview
FYI input number for preview = 0
TL68 on 1/16/2024(UTC)
TL68
#3 Posted : Wednesday, January 17, 2024 6:19:33 PM(UTC)
TL68
Sweden
Thanks for input, Doggy!
Got some progress when using input number. So making the api call from browser with:
http://localhost:8088/api/?function=SetRateSlowMotion&Input=2&Value=0.5
works!
But strangely using the same call in companion still does not work. So this does nothing:
SeRateSlomo not working
I have tried without the "0" and changing to comma but it did not help.
I use other cusom commands in companion which works so companion seems to connect as it should to vMix.
So what am I doing wrong here?
dmwkr
#4 Posted : Wednesday, January 17, 2024 7:19:31 PM(UTC)
dmwkr
Was thanked: 119 time(s) in 108 post(s)
From the readme at https://bitfocus.io/connections/studiocoast-vmix :
Using Custom Commands/shortcuts<br /> When using vMix shortcuts, please follow this syntax/layout, with space before the first value:
ReplayMarkInOut Value=5000
and if there is more than one parameter use "&" as a separator between them like this example:
SetOutput2 Value=Input&Input=3
thanks 1 user thanked dmwkr for this useful post.
TL68 on 1/17/2024(UTC)
#5 Posted : Wednesday, January 17, 2024 7:21:56 PM(UTC)
works!
Sounds like a Companion issue
TL68
#6 Posted : Wednesday, January 17, 2024 7:57:20 PM(UTC)
TL68
Sweden
Aaahhhh! Of course: a space before the first value!!
As always the saying "The devil is in the details" is true.
Now it works like a charm! Big thanks dmwkr!
