Joined: 12/27/2012(UTC) Posts: 5,103 Location: Belgium Thanks: 285 times Was thanked: 924 time(s) in 763 post(s)
Any reason one can not select 30p or 60P framerates for a new HD project instead of 25/50 (preset) ? is this based on national settings of vMix system? Am aware i can change it in the settings Screenshot 2024-01-01 132511.jpg (34kb) downloaded 2 time(s).
Joined: 3/30/2023(UTC) Posts: 55 Location: Chicago Thanks: 8 times Was thanked: 2 time(s) in 1 post(s)
I'm assuming it's not a bug because it's was that way in ver 26 and earlier.
Joined: 1/13/2010(UTC) Posts: 5,163 Location: Gold Coast, Australia Was thanked: 4176 time(s) in 1499 post(s)
It's a choice we have made due to how many cameras misreport their frame rates. For example broadcast cameras which report 60i or 60p in their settings are actually in reality 59.94i/59.94p. Same applies to 30p which is usually 29.97p.
The exception to this is some Chinese branded PTZ cameras which never properly supported "fractional" frame rates.
Users can of course go to Settings and change the Master Frame Rate manually, but we want to try where possible to steer people towards selecting the correct frame rate, and that is usually 29.97p/59.94p
Martin vMix
