Beta Discussion
tweak request: SoloAllAreOff in the Web API
Joined: 2/18/2014(UTC) Posts: 1,823 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
Haha! The great features with a SoloAllOff shortcut and Solo indications added in beta 27.0.0.52 almost made my small scripts contributions for similar things obsolete. I say almost, because there is no node in the API that reflects the Solo indication shown by vMix. It would for sure be more convenient to have one there. In particular for those who can´t run VB.NET scripts.
Joined: 3/12/2015(UTC) Posts: 480 Location: Kansas City, MO USA Thanks: 149 times Was thanked: 75 time(s) in 57 post(s)
+1
Yes an "any" solo indicator API Feedback seems to be that last piece of the puzzle. I am thrilled that vMix is now a Pro Audio solution.
The only missing piece is side chain connections in VST plug-ins, but I realize that that is a high end ask.
Steve
Joined: 1/13/2010(UTC) Posts: 5,163 Location: Gold Coast, Australia Was thanked: 4176 time(s) in 1499 post(s)
Perhaps if you provide a real world use case here it will help us understand better what is missing. The API already has the solo status of inputs in both the HTTP and TCP APIs.
Thanks, I apologize for my vague description. My use case was for a more efficient feedback solution for the vMix module for Companion (i.e. instead of a script that constantly checks all Inputs). I thought that since there was a Solo indication on the main screen, it would be easy to add it's content to the API. What then happened, or rather thedist did, a few days after was to add this functionality into the Companion module. And my script still works for users than don't use Companion. So, let's consider this tweak idea closed.
1 user thanked richardgatarski for this useful post.
Originally Posted by: richardgatarski Thanks, I apologize for my vague description. My use case was for a more efficient feedback solution for the vMix module for Companion (i.e. instead of a script that constantly checks all Inputs). I thought that since there was a Solo indication on the main screen, it would be easy to add it's content to the API. What then happened, or rather thedist did, a few days after was to add this functionality into the Companion module. And my script still works for users than don't use Companion. So, let's consider this tweak idea closed. Yes I think everything is good now! Thanks Martin and Team vMix!
Beta Discussion
