Beta Discussion
BUG: Max Particpant Resolution selector [Fixed]
Joined: 5/6/2016(UTC) Posts: 83 Was thanked: 5 time(s) in 5 post(s)
When adding a Zoom input, it defaults to to 360P on the actual input. If you then try to change it to 1080P right off the bat by right-clicking the input window, it won't allow it (stays at 360P). If you select another resolution (say 720P for instance), it will allow you to change it. Then after that it will work fine and you can change it to 1080P. It seems to be a problem with just that first selection - it won't let you select 1080P until you select another resolution first. Repeatable on my end. If you don't see the same behavior let me know and I can provide further info. This is in 27.0.0.49. May be related to this post: https://forums.vmix.com/...-Not-Reporting-Correctly
Joined: 8/2/2013(UTC) Posts: 1,038 Location: Fairhope, Alabama USA Thanks: 543 times Was thanked: 197 time(s) in 163 post(s)
I've experienced the same behaviour.
- Tom
+1 this issue. I had to select a different resolution before I could select 1080p, and then it appeared to work.
Beta Discussion
