Beta Discussion
Layer controls showing on other tabs
Joined: 2/23/2019(UTC) Posts: 134 Thanks: 15 times Was thanked: 28 time(s) in 25 post(s)
If you go to to the layers tab of input setting for an input with layers enabled, then switch to the Triggers or Tally Lights tab, the layer control toolbar (move, crop, border, size fields) stays visible at the bottom of the window.
Beta Discussion
