fabbryt
#1 Posted : Wednesday, October 25, 2023 12:46:25 AM(UTC)
fabbryt
Italy
Hi everybody,
Is it possible in the future to use the 2 recorder independently like streams?
Now if i start record, vmix use both recorder, but i would like to use one of this at a time.
In this way i don't have 2 file every time if not necessary.
Thank You.
mavik
#2 Posted : Wednesday, October 25, 2023 9:46:09 PM(UTC)
mavik
Was thanked: 166 time(s) in 148 post(s)
Maybe you can enable/disable the 2nd during recording of the first. Just try it.
fabbryt
#3 Posted : Thursday, October 26, 2023 12:34:37 AM(UTC)
fabbryt
Italy
Yes but i can't activate only the recorder n°2.this Is a small problema for me.
mavik
#4 Posted : Thursday, October 26, 2023 1:22:15 AM(UTC)
mavik
Have you tried the multicorder as well. You could use the recorder for one task and the multicorder for the 2nd independent recording.
nikosman88
#5 Posted : Thursday, October 26, 2023 5:40:26 AM(UTC)
nikosman88
Greece
Was thanked: 53 time(s) in 50 post(s)
+1
Roy Sinclair
#6 Posted : Thursday, October 26, 2023 6:15:42 AM(UTC)
Roy Sinclair
Was thanked: 22 time(s) in 18 post(s)
Originally Posted by: fabbryt Go to Quoted Post
Hi everybody,
Thank You.
Press the "Gear" icon next to the "Record" button. In the popup Recording settings window press the "2" button, when you get the settings for the second recording Uncheck the "Enable" button.
Then you'll get just one copy.
If you want to record a Different Output with the second recorder then select a different output on the screen for the second one instead of turning off the "Enable" button.
nikosman88
#7 Posted : Thursday, October 26, 2023 8:40:28 AM(UTC)
nikosman88
Greece
Hi everybody,
Thank You.
Hello. The problem is when we have the 1st recorder on progress, and we want to record something else for a small amount of time in the 2nd recorder is not possible to start-stop the 2nd recorder without interrupt the 1st recorder. Also another feature i would like to see in the future is a way to change while recording is on progress with a shortcut the audio bus that we record. Also i would like to see in multicorder the same process to be enabled (change audio bus while multicorder) and also be able in audio to record and audio buses and not only master or input
Roy Sinclair
#8 Posted : Thursday, October 26, 2023 9:42:22 AM(UTC)
Roy Sinclair
Hi everybody,
Thank You.
OK, that's what was missing from your first description and therefore why what I noted as being already there doesn't satisfy your true need.
Pavel
#9 Posted : Saturday, October 28, 2023 5:53:15 PM(UTC)
Pavel
Yes, but at the same time there cannot be Instant Replay.
#10 Posted : Saturday, October 28, 2023 6:12:16 PM(UTC)
Was thanked: 921 time(s) in 760 post(s)
if the car has only 4 seats and need to transport more people than that:
- buy a second car
- buy a van with more seats
- hire an extra car, taxi, uber,....
nikosman88
#11 Posted : Saturday, October 28, 2023 6:47:25 PM(UTC)
nikosman88
Greece
- buy a second car
i agree at a point with you but... If a car has 4 doors (1st recorder front doors and 2nd recorder back doors) and if the back passenger needs to get in/out of the car must the front passenger also get in/out from the car,there is an ergonomical mismatch in the whole design
richardgatarski
#12 Posted : Friday, March 8, 2024 4:16:14 PM(UTC)
richardgatarski
Was thanked: 292 time(s) in 246 post(s)
+1
Use case (one example). In 2 hours we will go live with a conference production. Now the Swedish Minister for Energy, Business and Industry and Deputy Prime Minister asked if we could give her secretary a file with her key note immediately after. She need it for a press conference this morning. My problem is that the conference continues for three more hours, and we need to record the whole thing.
/richard
(in the back seat and, I can't use the rear doors)
jet
#13 Posted : Friday, March 8, 2024 9:56:10 PM(UTC)
jet
Was thanked: 15 time(s) in 13 post(s)
+1
