Beta Discussion
Bus mixer / headphone [FIXED]
Thanks: 10 times Was thanked: 32 time(s) in 27 post(s)
The headphone level of an input can be adjusted by the small rotary inside the audio inputs settings and inside the new bus mixer.
I would suggest to remove the "H" from the bus mixer. - Inside the vMix application the headphone output is never called a "Bus". - Headphone is not part of the output section in the Audio Mixer as a full bus (with all the controls). - Dialogs are more consistent: Headphone level is controlled with a rotary inside the audio input settings and inside the Audio Mixer. - Headphone is not part of the new Audio Bus Manager.
Best regards, Patrick
Joined: 2/18/2014(UTC) Posts: 1,823 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
Aha! Perhaps the H was in the Bus mixer's column that in 26.0.0.47 resides between M and A. That empty column confuses me, perhaps it will be removed.
Beta Discussion
