Cheers to the vMix team. Thank you for access to the preview of 27. I've been using vMix with Zoom for a couple of years (via NDI). PLeased to see the integration in 27, but confused regarding the addition of participants to a (single) meeting. When one attempts to add an input (per the instructions) "The maximum number of Zoom inputs for this edition has been reached" is displayed. ("Once the main Zoom input has been added, go to Add Input - Zoom again to add additional inputs. These inputs will connect to the same meeting."). Clarification on this matter would be appreciated. (One cannot see the participants in a meeting unless one joins via the Zoom app. Adding participants via separate inputs, as the instructions appear to indicate, would make it possible to view the full meeting roster, as well as interact with participants to fold back to the meeting. I trust this makes sense.)
Joined: 2/18/2014(UTC) Posts: 1,821 Location: Stockholm
Thanks: 138 times Was thanked: 292 time(s) in 246 post(s)
Thank you. That part is clear. Ostensibly, my message is not. Yes, you can select which participant appears in the (one) input. The instructions seem to suggest that you can bring up each participant in their "own" input - thus, seeing all the participants in vMix at once.
For more than one Zoom Input you need at least vMix 4K.
That's what I thought. A workaround is available for my purposes. At least the video link is present.
