GT
Change Text Colour as WebRequest
Joined: 11/20/2020(UTC) Posts: 74 Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
Hi Folks, I have a piece of working code: Code:request2 = HttpWebRequest.Create("http://127.0.0.1:8088/api/?function=SetTextColour&Input=Videotimer&value=red")
//I cut out response etc...
as soon as I try to call the colour via hex e.g. #FF0000 it is not working. wether it throws an exception or the text gets transparent? colour value in title editor then is "00000000" I tried $"....value={#FF0000}" (transparent) ; $"....value='{#FF0000}'" (exception) and what not anybody a clue?
Joined: 12/27/2012(UTC) Posts: 5,103 Location: Belgium Thanks: 285 times Was thanked: 924 time(s) in 763 post(s)
Originally Posted by: Chris Daum Hi Folks, I have a piece of working code: Code:request2 = HttpWebRequest.Create("http://127.0.0.1:8088/api/?function=SetTextColour&Input=Videotimer&value=red")
as soon as I try to call the colour via hex e.g. #FF0000 it is not working. wether it throws an exception or the text gets transparent? colour value in title editor then is "00000000" I tried $"....value={#FF0000}" (transparent) ; $"....value='{#FF0000}'" (exception) and what not anybody a clue? See the helpfiles "URL encoding may need to be used when using special characters in the Value parameter" https://tvcrew.ch/wiki/d...ers_in_urls_api_via_httphttps://www.w3schools.com/tags/ref_urlencode.ASP
cool, thanks Doggy ...%23... who thought about something like that... you were right format problem... and thanks for the links. I mean over the years I did a lot of research but never found these two sites!!!
GT
