David_in_Philly
#1 Posted : Wednesday, October 18, 2023 7:06:28 PM(UTC)
David_in_Philly
Was thanked: 13 time(s) in 8 post(s)
>Added support for the audio "Mix" from Zoom instead of isolated audio feeds per participant.<
Awwww...I was really looking forward to using the ISO audio from Zoom. This feature is only currently accessible from Zoom ISO itself. I agree with the need for for mix audio too, so perhaps you could add a "mix" input from Zoom (audio only) or perhaps combine it with active speaker video support.
Please, Martin, don't take the Zoom ISO audio away! Please?
#2 Posted : Wednesday, October 18, 2023 7:11:48 PM(UTC)
Was thanked: 4174 time(s) in 1498 post(s)
It's probably a good idea to try the latest vMix update before posting.
If you did you would see it is a toggle option between them.
The "instead of" in the feature wording is meant that you can choose this option instead of ISO if you want to.
But I have updated that line to prevent any further confusion.
But please, actually try the updates before posting here...
sinc747 on 10/19/2023(UTC)
David_in_Philly
#3 Posted : Thursday, October 19, 2023 1:40:58 AM(UTC)
David_in_Philly
Sorry. Will do.
