Hardware Compatibility
vMix Crashes - Quits Completely - HELP
Screenshot 2023-07-02 170959.png (154kb) downloaded 0 time(s). Screenshot 2023-07-02 171014.png (243kb) downloaded 1 time(s).
I found a potential issue.
When the same NDI Sources are opened for example:
vmix machine 1 - 3 NDI SOURCES
vmix machine 2 - SAME 3 NDI SOURCES
CRASH
Same if i open NDI VIEWER on my ipad. VMIX CRASHES
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4175 time(s) in 1498 post(s)
Originally Posted by: admin I have never had an issue with Bitdefender. How can you find out its related with Bitdefender just out of curiosity
Joined: 11/23/2020(UTC) Posts: 163 Location: Wichita Thanks: 9 times Was thanked: 22 time(s) in 18 post(s)
Originally Posted by: enzostrano Originally Posted by: admin I have never had an issue with Bitdefender. How can you find out its related with Bitdefender just out of curiosity You thought that you've never had a problem with Bitdefender but since this IS a problem with Bitdefender that's not true any more. I would guess they looked at what they were doing at the point the dump showed they were executing and then looked up reasons other people have had with doing that and Bitdefender was implicated. They may have exhaustingly traced it down in the failing system if they had easy and complete access to it but most of the time someone else had also stumbled across the same problem and noted it. The fact that they identified it as a problem in Bitdefender based on the small amount of information you gave them is a pretty good clue that they know that problem well.
