mkoobchi
#1 Posted : Monday, June 26, 2023 3:36:27 PM(UTC)
mkoobchi
Iran (Islamic Republic Of)
vmix is great software for playout but i have problem with after effect vr template and vmix , i have vmix pro and creat studieo template with after effect and blackmagic capture card but when add the talent in after i cant connect after to vmix for move talent to vmix and slide talent in vmix with ndi
Egriswold
#2 Posted : Tuesday, June 27, 2023 9:39:35 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
You should post this in General Support, Second, sounds like you're doing this the hard way, why not just render out the set as a video file and load as background in vmix. It would be helpful if you were more descriptive and uploaded screen shots.
Joeboe
#3 Posted : Tuesday, June 27, 2023 10:50:52 PM(UTC)
Joeboe
Maybe you are adding the background the wrong way....are you using the Virtual Set template to do this, and is the talent on a green or blue background.....maybe you should do a google search or youtube search for using green screen in vmix, or using a virtual studio
Take a look at this video
https://www.facebook.com/watch/?v=373859086729015
