Hardware Compatibility
Blackmagic Duo 2 Audio is choppy after more than one input
Joined: 6/21/2022(UTC) Posts: 4 Location: Chicago, IL
I have a blackmagic duo 2, it's all updated on firmware, etc.
I added a few inputs to vMix and if I just have one input, the audio is fine.
If I add a second vMix input from the Blackmagic card, I can see the video just fine but it will have choppy audio for all the Blackmagic inputs.
Is there any way I can fix this or do I have a crappy card?
Joined: 7/16/2021(UTC) Posts: 17 Location: Legnano Thanks: 2 times
Originally Posted by: willenglishiv I have a blackmagic duo 2, it's all updated on firmware, etc.
Is there any way I can fix this or do I have a crappy card? If you have good audio changing sdi input and the problem starts only with more than one sdi connected, I think that your machine has some audio problems , Have you tried to reinstall audio drivers?
Originally Posted by: miro_lee Originally Posted by: willenglishiv I have a blackmagic duo 2, it's all updated on firmware, etc.
Is there any way I can fix this or do I have a crappy card? If you have good audio changing sdi input and the problem starts only with more than one sdi connected, I think that your machine has some audio problems , Have you tried to reinstall audio drivers? I can but I'm very confused at this point, especially with my Windows 10 machine everything works perfectly with no work around. My Windows 11 machine is the one that is having problems and I'm strongly considering building a rig for it :(
Joined: 12/24/2021(UTC) Posts: 356 Location: athens Thanks: 113 times Was thanked: 53 time(s) in 50 post(s)
Originally Posted by: willenglishiv Originally Posted by: miro_lee Originally Posted by: willenglishiv I have a blackmagic duo 2, it's all updated on firmware, etc.
Is there any way I can fix this or do I have a crappy card? If you have good audio changing sdi input and the problem starts only with more than one sdi connected, I think that your machine has some audio problems , Have you tried to reinstall audio drivers? I can but I'm very confused at this point, especially with my Windows 10 machine everything works perfectly with no work around. My Windows 11 machine is the one that is having problems and I'm strongly considering building a rig for it :( Windows 10 perfect. Windows 11 not. So What is the crap thing in this? Windows 11.. We stick with windows 10 until Vmix guys gives us the fully green light for bug free vmix and windows 11
