Steve F
#1 Posted : Friday, May 5, 2023 5:28:50 AM(UTC)
Steve F
Relatively newbie here.
I am trying to use the multicorder to record multiple NDI channels. I am receiving many drops frames (about 30 per second) when any of the four NDI cameras are set to 1080P60.
I had this working prior to company move which required a reload of Vmix, new config, NDI camera firmware upgrades,
Here is the setup
Four Birddog P200 NDI cameras
Wired ethernet in Ubiquiti US-8-150W POE switch
MSI Laptop I7 RTX 3060
If I set the NDI cameras to output 1080P30 I can multi-record all channels to an external USB SSD Drive, CPU and GPU don't even break a sweat, both at around 10% usage maybe 1 dropped frame per few minutes.
If I switch any NDI camera to 1080P60 I get frame dropouts at about 30 frames per seconds (you can see the dropouts chug along at a constant rate)
If i go into the Birddog controller and switch the NDI bandwidth, it doesn't matter, same drops outs
If I try to record 2 cameras, as log as 1 is 1080P60, i get dropouts.
Changing the recoding bitrate doesn't seem to matter
My Vmix project is set to 1080P60
As I said, i am not an expert, we recently upgraded VMix to the latest version, and we updated the firmware in all of our birddog cameras (to keep all the same since since we bought a new one)
I am not sure if it is a Vmix settings issue ... network bandwidth issue.
prior to a company move, i am almost certain I was able to record all at 1080P60
Thank you in advnace for your help!
